SRAM road braake bl...
SRAM road braake bleeding
[#12726535]
Who has any little tips? I have two bikes set up with these brakes and I am damned if I can get the back ones right. Always a bit more lever pull than the front.
Fronts seem to be easy and although I replicate everything at the back nowt really works.
I have tried all sorts of variations on the standard method. grrrrr
Posted : 16/02/2023 6:58 pm
You and me both - really tricky - apparently easier with 2 people and with the caliper removed... My AXS button squashes my fingers when I pull the brakes from the hoods on the rear brake. Does my head in.
I've got to do it next week... Ugh.
Posted : 17/02/2023 12:55 am
From experience of bleeding absolute shedloads of Avids and Srams over the years, I can tell you it takes a lot longer to do it properly than thair blurb suggests. First thing I always do is excercise the pistons (clean & lube with silicone first if they're not new), and when you're sucking out the bubbles, don't stop when the instructions tell you, keep going for a good 10 minutes more (a series of short fast pulls, followed by one long, drawn out one seemed to work best).
Posted : 17/02/2023 7:53 am
Another vote for removing the rear caliper and hanging it below the chainstays.
Posted : 17/02/2023 10:33 am
Caliper off, clean the pistons and seals, and check you've got the reach adjuster all the way out for bleeding, then get them level afterwards using it (although it's a bit vague feeling between the 4 positions but it does work).
Posted : 17/02/2023 12:13 pm
I do most of my maintenance myself, but my gravel bike is currently with my LBS to bleed the (SRAM Force) brakes and put a new gear cable (inner & outer) in...
Posted : 17/02/2023 12:52 pm
Been at it for ages. Spent an hour on one with the calpier on the floor ro try to get a flow with no down hills. It has to be something to do with it being the rear as I do the front ones perfectly every time and never get the rears right. I have never sent a bike to a shop before in over 50 years apart from a rear shock to Mojo in 06. This may be the first.
Posted : 18/02/2023 4:26 pm
