SRAM crank removal ...
[Closed] SRAM crank removal fiasco
Some mug on pinkbike will buy this
I'll give you a tenner if you throw in whatever tool you used to end that bastard - looks like it'd take out a T1000.
Posted : 09/09/2016 7:02 pm
The saga continues...
Ordered a Praxis BB and a set of XT cranks. 11 speed single ring.
However the cranks have arrived and they appear to have bolts for two chainrings.
Everything on the box says single 11 speed. Is this the wrong crank in the box???
Posted : 12/09/2016 8:56 pm
Pretty sure that's how they come
Posted : 12/09/2016 9:07 pm
Yep the crank arm is the same for 1x and 2x......
....just the chain ring bolts for 1x are longer.
Posted : 13/09/2016 1:26 pm
Let me know what you think of the praxxis
Posted : 13/09/2016 1:35 pm
[quote=renton ]Let me know what you think of the praxxis
Will do. My mate ran one with no problems. Just looks infinitely better than the SRAM one. Much bigger bearings that sit outside the shell, so if the BB shell does fill with water, which mine does as there's no drain hole, then at least the bearings aren't sitting in water. Bearings on the Praxis are also replaceable/upgrade-able if required.
Posted : 13/09/2016 1:59 pm
Page 2 / 2
