SRAM 11 speed repla...
[Closed] SRAM 11 speed replacement outer mech cage?
[#8464886]
I've just managed to crack/splinter/break the bottom end of my XX1 rear mech cage, end result is the chain can now jump off the bottom jockey wheel and jam up.
My google-fu is not showing this available as a separate part (you can buy the beefy ally inner cage plate, but not the outer breakable carbon one - go figure...). Anybody know if an aftermarket manufacturer makes one?
(I've stuck a wanted ad up, but if anybody has a broken 11 speed SRAM rear mech with an intact outer cage - I have cash waiting!)
Ta,
Jon
Posted : 21/04/2017 6:17 pm
It is not a separate part because the bolt holding in the clutch (and the cage) is pinned since they introduced type2 and cannot be removed without breaking everything.
Posted : 21/04/2017 8:30 pm
If you need to buy new then have a look at the half price XO drivetrain on Start Fitness web site. It may work out cheaper in the long run with a spare cassette and chain, and maybe sell the shifter on
Posted : 21/04/2017 8:49 pm
