square taper bottom...
[Closed] square taper bottom bracket 'sleeve'
[#11473955]
Another square taper question as my google powers have failed me.
I have a square taper bb, all fine but the non-drive side sleeve thingy is plastic and cracked - all i want to do is replace that with a metal one...but seems it's not a part you can buy on its own?
It's not specific to each bottom bracket (assume same for all 68mm shell BBs) so strange that I can't find one.
Am I just calling it the wrong thing or is it just that BBs are so cheap you're just supposed to buy a new one?
cheers
Posted : 11/11/2020 12:17 pm
They're not something that generally wears out, so they come with the BB. If you're on good terms with a bike shop, they will probably have a bunch of them in their junk heap.
Posted : 11/11/2020 12:26 pm
theres a few on ebay (resin mostly from my quick search..) not cheap tho compared to a new BB...
do a search for bottom bracket cup as opposed to sleeve..
id just buy a new BB and keep it for a spare looking at the prices of the 'cups'
Posted : 11/11/2020 12:37 pm
While they are not specific to each bottom bracket there are different sizes so you can't just buy a 'spare' and assume it will fit. I suspect even if it was available it'll be half the price of a new BB. I'd go with the advice above, a friendly chat with a bike shop or buy a new BB and keep the other bit as a spare.
Posted : 11/11/2020 12:41 pm
I would imagine that your time and money is much better spent on a new bb.
Posted : 11/11/2020 12:42 pm
Thanks all. Will ask about, but does look like its a case of just buying another BB - cheers
Posted : 11/11/2020 1:20 pm
Your best bet is the spares bin at a friendly local bike shop.
As above - they aren't always interchangeable. I've had to tickle Shimano metal cups in a lathe so they would fit in place of plastic ones.
If the plastic NDS one is just a single crack then they will still work - just don't go crazy with the spanner.
Posted : 11/11/2020 1:22 pm
Any regular bike shop mechanic should be able to dig one out of their bin for you.
Posted : 11/11/2020 1:38 pm
