I gather this is the same as the Zesty but due to the lack of tech docs that's not very helpful...
I've tried and failed at 1x so I'm going back to a front shift.
I've got the adaptor plate on order from Hotlines via LBS but no one seems clear if it comes with the bolts or not.
I'm looking to use an FD M 785 mech and I think from reading Shimano's tech PDF it doesn't have the bolts either.
http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=69485
From what I can see, the plate has three bolt holes and the FD two- I'm guessing the little one to the side is location/plate retention for when the mech's off.
If anyone can help me out with bolt sizes it would be most appreciated (or if I've got the mech totally wrong!)
Finally... That M785 with its rating for 38-40t front - am I going to be ok with a 36t big ring?
