Specialized S Works...
[Closed] Specialized S Works Stumpy Carbon...
[#1422252]
Does anyone know on here if you can get a replacement bottom bracket other than the shimano press fit one that comes with Specialized S Works? Has barely lasted 6 months and is starting to sound very rough ;-(
Was wondering if it would be possible to get a ceramic bearing replacement to fit the current cups that are pressed in?
Any advice greatly appreciated 😉
Cheers Stu
Posted : 18/03/2010 1:31 am
There will be a code on the bearing currently in there, for example '6902RS' (Hope Pro II axle bearing). These bearings are sure to be prodced for other applications so take that code and get on to your local tool shop/hardware outlet and get hold of some. Or order them online, obviously
Posted : 18/03/2010 9:08 am
