specialized 2.3 tyr...
[Closed] specialized 2.3 tyres on wide rims?
[#10371871]
How's the profile of specialized 2.3 tyres on a wideish rim? looking at butcher/hillbilly on a 33mm ID rim. Do theses end up flat across the tread with sidewall poking out past the side knobs?
Posted : 04/12/2018 8:21 pm
Got a Hillbilly on a 30mm internal, looks mahoosive in a good way. Seems to fit fine.
Posted : 04/12/2018 9:43 pm
Specialized's own Roval wheels are fairly wide (over 25mm iirc).
A 2.0 looks really wrong at that width but the 2.3 butcher/ 2.2 captain combo I run looks good. Nice and chunky.
Posted : 05/12/2018 12:00 am
2.3 Slaughter on Hope 35w looks ok.
2.6 Hillbilly on Hope 35w looks bigger.
2.6 Butcher on Hope 35w bigger still.
2.6 DHF on  Hope 35w bastard massive.
Posted : 05/12/2018 1:21 am
 sv
The '2.6' Butcher only measures 2.4 on my 30mm ID rims.
Posted : 05/12/2018 12:07 pm
2.3 Slaughter on 30mm ones here, pretty decent profile.
Way better than my mate's Minion SS on an Arch mk3, which is practically flat
Posted : 05/12/2018 2:03 pm
Running a 2.3 Butcher control up front on a mk3 Stans Flow.
Profile is pretty much spot on.
Posted : 05/12/2018 8:41 pm
Bit of a thread resurrection as I’ve just put some Arch Mk3 rims (26mm internal / 29mm external) on my 2017 Transition Scout. I’ve got a 2.3” Hillbilly up front and a similar width Eliminator on the rear - both Grid spec.
I’d previously had a Butcher/Eliminator setup on much narrower rims and riding the new wheels the other day, I really felt like there was a bit of understeer on the front and came off a couple of times on some slippery / rooty singletrack lines.
Most of that’s probably down to gaping holes in my ability riding technical stuff, but I’m wondering about tyre pressures? I had 22psi in the front and it did feel pretty firm - is it likely I need to drop it a bit? The bike and I aren’t the lightest of things...
Any advice greatly appreciated!
Posted : 30/12/2018 7:08 pm
