Soldering Iron reco...
[Closed] Soldering Iron recommendations
 jere
[#3329302]
My soldering iron has stopped working as the end of the tip will not heat up or take solder and i can't get a replacement tip. can anyone recommend a good soldering iron?
Posted : 08/11/2011 1:42 pm
weller,
or pace if you have a bit of cash
Posted : 08/11/2011 1:58 pm
Depends what you want to spend, what you're using it for and how much you use it
The Antex ones from Maplin are good enough for most
Posted : 08/11/2011 2:03 pm
Cheap ones are generally rubbish. I'm lucky to have an aged Weller with an out-board PSU and is thermostatically controlled that simply works. Probably would have been expensive new.
Posted : 08/11/2011 3:09 pm
 jere
i'll have a look at the weller ones as the cheap one that i have that is broken was one from Maplins
Posted : 08/11/2011 4:27 pm
50w [url= http://mobile.maplin.co.uk/module.aspx?moduleno=35016 ]solder station[/url] from marlin is pretty good. Currently only 19.99
Posted : 08/11/2011 4:50 pm
Antex work OK for me and tips are readily available. I paid extra for the silicon rubber cable as I think the cheaper ones with the standard cable just gets in the way of whatever you are trying to do, in my opinion!
Posted : 08/11/2011 5:14 pm
I use a lighter gas powered soldering iron. Absolutely superb, controllable heat, six different tips and no cord to get in the way.
Posted : 08/11/2011 7:25 pm
 OCB
Antex for me too ...
Posted : 08/11/2011 7:42 pm
