SLX M7000 on 10 spe...
[Closed] SLX M7000 on 10 speed 11-46 cassette?
[#9787837]
Morning all - above says it all really - I'm sure it should work, but has anyone tried it and can advise either way? Just fitted a new Sunrace 11-46 cassette, then mangled the 10 speed mech.... perfect timing!
Posted : 23/01/2018 9:30 am
If you mean with a 10s shifter, I ran an XT 11s mech with an XT 10s shifter & cassette (with expander). Worked much better than the 10s mech with RAD cage.
Posted : 23/01/2018 9:39 am
Yep, all 10 speed, except it is an SLX front shifter I think (not that that should make any difference) - cheers Fathomer. I'm looking at the SLX specifically as that is supposed to go up to a 46T on a 1x set-up, which is what I have.
Posted : 23/01/2018 9:57 am
You want the 11spd SLX mech, not the 10spd version.
The 11 goes up to 46t sprocket, whereas the 10 only 36t (officially)
Posted : 23/01/2018 1:36 pm
Ah just realised that they do a 10-speed in the M7000 range, but I meant the 11 speed anyway - cheers
Posted : 23/01/2018 5:47 pm
