Looking at getting an SLX double n bash with the correct 2sp front mech.
Anyone had any issue with running SRAM shifters on this set up?
(will be running a SRAM rear mech.)
should be fine, pull ratio on fronts is the same
I run a XT front with my double and bash - so no need to buy the specific mech unless you have too. You just adjust the top limit screw to 2 rings use.
Lurker post.
Im having no problems using an x7 shifter with the slx double only mech.
No problems here, SLX double and front mech with SRAM rear X9 mech and X0 gripshift front and rear.
Works a treat.
I've been using an XTR front mech with X0 shifters for a couple of years with no problems.
It's a bit different with Grip Shift, because you can 'trim' the front mech to get adjustment right.
It will work with triggers though, with either a normal front mech, or the double SLX one, the advantage being a slightly smaller radius curve on the SLX to better match smaller rings.
Cheers for the info
X9 shifters, X9 rear mech, XT front mech, SLX Double - No problems - I love this set up!!!
