Need to order some replacemnet pads for the Sram Guide R - I see they come in Sintered or organic.
What are the main differences and what would make you choose 1 over the other?
Also was going to get a Bleed Kit for my brakes. I see that there are 2 versions. My bike is a 2018 model so should I assume I need the newer kit (for 2017 onwards Sram Brakes) or is there a way to check if you have newer or older versions?
https://www.epicbleedsolutions.com/products/bleed-kits/avid/
https://www.epicbleedsolutions.com/products/bleed-kits/sram/sram-bleed-kit/
Sintered front, organic rear.
Reason for mix and match?
Sintered F&R as ride a lot in the Peak and organics don't last that long in wet gritty paste. Might swap to Organic for a trip to Madeira, if I remember.
1/2 decent write up here on the differences - https://www.worldwidecyclery.com/blogs/worldwide-cyclery-blog/mountain-bike-brake-pads-sintered-vs-organic
https://www.epicbleedsolutions.com/resources/faq/what-is-sram-bleeding-edge-tool/
Should help identify which caliper you have. As you say, you'd assume the newer version with the bleeding edge thingy
HTH
Carlos
