Single speed conver...
[Closed] Single speed conversion
[#2911104]
I need to get a new BB to convert to single speed, what spindle length do I need?
Shell is 73mm and I'm using DMR conversion kit on rear hub, thanks.
Posted : 03/07/2011 11:39 pm
Try it with your old BB first and check the available chainlines with the chainring in the middle and outer positions on the cranks. If you're converting a cassette hub (freehub) with spacers there should be some scope to make adjustments at the back as well. Don't get too anal about it - use a chain that's been designed for gears and it'll cope with the chainline being less than perfect.
Posted : 04/07/2011 9:42 am
I always use spacers from a couple of old cassettes to align the sprocket. I have some 8-speed ones which are slightly wider to allow for perfect fettling.
However, last week I went dinglespeed. I put a 36 and a 34 ring on the front and a 16 and 18 on the back. So I ride 36:16 from home to the Stepping Stones on Cannock Chase (35mins) Swap to 34:18 to ride around the Chase for a few hours then when I've got back to the road, swap back to 36:16 to pootle home.
Posted : 04/07/2011 9:49 am
What they said...and even if you did need a new axle we'd need to know what crank you are using.
Posted : 04/07/2011 9:51 am
The old BB was a hollowtech 2 and is on my new frame. The cranks are RPM with a 46 t chain ring to use for work city riding etc. The only BB I have is a 68mm shell.
Posted : 04/07/2011 9:54 am
get anything, stick it all on then work out your chainline, then space the back accordingly (requires a small amount of maths)
Posted : 04/07/2011 10:00 am
 D0NK
Big John what do you use for tension? I like the idea but sounds so much faff one of these might be better
Posted : 04/07/2011 10:06 am
They're both magic ratios on my Cotic Soul so with a new chain I don't need a tensioner. However I use a DMR Tension seeker and even with moving the jockey over the job takes about 2 minutes.
Anybody who rides with me will confirm I'm a faster fitter rider on singlespeed. With gears I just plod up the hills and lose fitness over a few weeks. I can't understand it either.
Posted : 04/07/2011 10:11 am
 D0NK
Not too bad then, hmm cx ss...
Posted : 04/07/2011 10:20 am
Thanks all
Posted : 04/07/2011 12:26 pm
