Simpleton Question ...
[Closed] Simpleton Question ..... Steepening frame angles ny 0.5 degrees - What affect?
[#4497585]
As above.
Slightly confused.
Posted : 26/10/2012 9:17 am
Not much. same as Running a slightly soft front tyre...
Posted : 26/10/2012 9:22 am
So dip the front end a bit?
Posted : 26/10/2012 9:23 am
It will make no discernible difference, changing the front tyre would have a bigger affect on handling.
Your frame will be 0.5 degree steeper. Not much
Not a lot either way, but if achieved through shorter forks or more fork sag or smaller front tyre you'll also lower the BB whilst if done through headset angle cups or a larger rear tyre or less rear suspension sag you'll also raise the BB.
Posted : 26/10/2012 9:36 am
Just for clarity the change would come from using an internal headset cup rather than the external one presently.
Posted : 26/10/2012 9:45 am
Will the fork still clear the downtube?
Posted : 26/10/2012 10:13 am
chiefgrooveguru - Member
Yes.
Bars/forks would still spin freely.
Posted : 26/10/2012 10:33 am
What affect?
[s]nearly[/s] sod all.
hth.
Posted : 26/10/2012 10:36 am
