Just received hopes hoops pro 3 XC wheels and can't find the 3 bolt rotor for sale anywhere online. This is crap for me because I don't have a Hope dealer anywhere near me! Emailed Wiggle who sold the wheels, but they say they won't special order parts for customers.
email 18bikes in Hope they will sort you
I thought you were meant to specify which ones you wanted and get them with the wheels?
The rotors are not included with the wheels. My fault for not checking this. Just think its ridiculous that wiggle sells the wheels and not the rotor they require to work. From now on I shall go to the LBS!
It's even worse they won't custom order the required parts!
Why does it give you a rotor size option when ordering then?
I'm with Grumm on this .When i ordered mine from LBS i had to specify which rotors i wanted .
They should come with them, wiggle list them with them...unless im missing something
Just looked on wiggle - you had to specify the rotor size you wanted, they should've given you some!
send them back, winstanleys are doing them with rotors for £305 a pair!
Wiggle customer service won't sort out the rotor and are saying its not included, so sending back for a refund. Lesson learned: read the whole description of what your're buying! Looks like it time to stand in line at the post office...
Should have got them from wheelpro and they come with the rotars, Great service as well
That is really weird as if you go to order the wheels they give you the choice of discs you require!
Yup definitely meant to come with a pair of rotors.
hope state those wheels as "with free rotors" bunch of cowboys lol
email/phone hope and explain the situation they will see you good im sure as well as have a word in wiggles ear
Wiggle are definately the bandits here, those wheels always come with rotors, no exeptions.
theres normally an option for a standard 3 bolt rotor or a "lightweight" 3 bolt rotor in 160/140mm sizes which has further laser cut out bits.
Merlin cycles are very good for sorting out ordering rotors for me 😉
I do have a 140mm lightweight rotor if you still need one? fitted but not used.
