Silencing a dropper...
[Closed] Silencing a dropper seatpost
 JoeG
[#5552971]
I have a KS Lev on my full suspension bike. Using carbon paste, it doesn't take long till the post starts to make a "click" when I shift my weight around on the saddle. If I clean and replace it, the noise goes away, but not for long. 😕
Does anyone have any tips for keeping the dropper quiet for longer?
Edit - Frame is Ti with an aluminum insert (not a shim!) about 4" long, 31.6 mm ID.
Posted : 27/09/2013 5:52 am
Replace it with a proper seat post - you don't need the dropper #kingsnewclothes
Posted : 27/09/2013 9:52 am
OP, sure it's the post not the saddle/rails?
Posted : 27/09/2013 9:55 am
What sort of clamp are you using? Sound like the post is slipping very slightly. I had exactly the same (maddening) issue with my Hope QR. Switched to a Thomson clamp and the problem disappeared.
Posted : 27/09/2013 10:21 am
JoeG - top tip - use a dab of carbon paste at the junction where the top of the stanchion meets the adjustable saddle cradle - the bit with the bearings on it. Seems to kill that slight sideways/rotational play in the saddle that I think is common with LEVs.
Posted : 27/09/2013 10:25 am
 JoeG
Its not the saddle clamp/rails. If I just pull the post, clean and apply new carbon paste (and don't touch the saddle/clamp) the noise goes away. For a short while.
The seatpost clamp came with the frame. Its not a QR, it has a M4 screw going into a barrel bolt. I guess that its not the best quality, so maybe an upgrade is in order.
stAn-Bad Brains MBC - Member
You are correct, I don't need one. I need two; one for my full suspension and one for my fatbike! 😆 My retrobike has a period correct dropper as well; a Hite-Rite! 8)
Posted : 27/09/2013 8:48 pm
