show me you garmin ...
[Closed] show me you garmin mounts
[#9546132]
on a mountain bike that is...
Currently got mine on my top tube using the standard rubber band job, i dont like it there, i cant see it properly either and i keep catching it with my knees.
tried the k-edge stem cap mount, but constantly knock it off when dismounting, either accidentally or on purpose. the bar mounted sticky out one gets snapped off in crashes out front, and i cant get the angle on right so its legible if it points backwards... hate having it just sat in the bars too....
Posted : 12/09/2017 6:38 pm
Drill and tap your stem and screw a standard mount into that
Posted : 12/09/2017 6:54 pm
I mount mine on a k edge stem mount like this, having the angle adjust is brilliant.
http://www.chainreactioncycles.com/mobile/k-edge-mtb-stem-adjustable-mount/rp-prod151499?gs=1&utm_source=google&utm_term=&utm_campaign=Chain+Reaction-UK-PLA-PLA-All-MB-SE-Shopping+QLB+Manufacturer+Mobile&utm_medium=base&utm_content=mkwid|snLdwZqwF_dm|pcrid|161810673982|pkw||pmt||prd|552299UK
Recently I used the mount that came with the garmin and used some sugru to hold it in place. It's been bomb proof.
Posted : 12/09/2017 6:55 pm
My 810 on my stem using the standard mount, etrex on a out front bar extender using the standard mount.
Posted : 12/09/2017 7:41 pm
 pnik
I'm using [url= https://www.tredz.co.uk/.SRAM-QuickView-MTB-Garmin-GPS-Computer-Mount_70340.htm?sku=215624&utm_source=google&utm_medium=cpc&utm_campaign=google_shopping&gclid=EAIaIQobChMIu7bluayg1gIVK7HtCh3BAgT9EAQYAiABEgJE8vD_BwE ]this one[/url] which is pretty good its a bit shorter than an out front and i've used it fine with 70mm and 50mm stems with my 810.
Posted : 12/09/2017 8:14 pm
Posted : 12/09/2017 8:15 pm
 rs
I tried the kedge angle adjust one, but it doesn't work well with short stems, maybe if you have spacers on top it'll be fine. I ended up buying the barfly one richie rude uses after seeing a pic online...
Posted : 12/09/2017 8:39 pm
How on earth do you knock it off getting off your bike?
Posted : 12/09/2017 8:54 pm
Getting off his bike = crashing 🙂
Yeah I've no idea but I do, and I've snapped loads of the plastic insert plates too... if I don't knock it off I hit the stop button with something!!
Never heard of Sugru but looks like it may just be the job!! My top tube mount is low because I need to get bands round, but with that stuff I should be able to tuck it in at the top..!
Where was the barfly from?
Posted : 12/09/2017 9:39 pm
