Should forks lose p...
[Closed] Should forks lose pressure over time ?
[#2993117]
As per title really. Got a hardtail 18 months ago and shop inflated forks ( fox float 32 r ) to suit my weight. Bought a shock pump the other day and found the pressure to be 55psi . No wonder i keep going over bars 😳 For my weight (15st) it should be about double that according to fox website. I think maybe the pressure loss was gradual and thats why I didn't notice or I'm cack handed and couldn't tell the difference anyway.
Posted : 29/07/2011 9:57 am
Very gradual loss is normal.
Posted : 29/07/2011 9:59 am
YOu will also lose some ech time you fit and remove the pump.
I wouldn't be too concerned about taht small loss although the air forks I have (zocchii and RS) don't lose air at all as far as I can see)
Posted : 29/07/2011 10:01 am
If you ride at all regularly I'd also look to get the forks serviced - 18months is a long time without touching them - Fox like a bit of tlc on a regular basis.
It really depends. Some forks do - particularly negative chambers as the volume is pretty low so small losses affect the pressure quite a lot.
Posted : 29/07/2011 10:02 am
Watched the video for the foam ring lube and will get some float fluid and do that. If they look really manky will go for a proper service
Posted : 29/07/2011 10:03 am
don't think so, not in my personal fork experience
Posted : 29/07/2011 10:10 am
