Shorter stem, riser...
[Closed] Shorter stem, riser bar
[#11389397]
My Scandal came with a 60mm stem and a flat bar. Am thinking of going to a 35mm with a low riser bar to make it a touch easier to lift the front end. But will I upset the handling by going too short/high?
Posted : 19/09/2020 7:54 pm
Only way to find out is to try it.
Posted : 20/09/2020 4:12 am
I bought a cheap stem or two (s/h ebay) and had a play around, you can always sell them on.
Posted : 20/09/2020 4:16 am
If you are keeping the same width then the theory is that the steering will be a bit quicker and less stable. Stems got shorter as bars got wider. In reality I wouldn't care about 25mm and would just change if it makes the bike fit better or ride more how you like.
Posted : 20/09/2020 8:00 am
This is the thing gto do if you're worried. You can get get bars for <£15 quid and a stem or two and test. Then if you feel the need for a posh one buy that when you're happy with the position and sell the rest or keep for other fit experiments.
Posted : 20/09/2020 8:21 am
I went for it... got Nukeproof bar and stem combo so now have an 800mm flat bar and 60mm stem going if anyone needs them for a build?
Posted : 23/09/2020 10:08 am
The Big Dog is advertised as suitable for a 35 to 50 stem. Standard On One then build them with a 60.... I specified a 50 and have just ordered a 35 off Ebay for £5.36. I'm assuming £4,50 of that is the P&P from China.
Posted : 24/09/2020 12:04 am
