short steep stems
[Closed] short steep stems
[#7846392]
just pondering a bit more XC front end.
can't find any 60 or 70 mm stems in 17 degree or even close. anyone make any?
Posted : 23/05/2016 10:07 pm
Hope do (or did), a 70mm x 25deg.
Posted : 23/05/2016 10:11 pm
Easton make a 70 degree stem in 17 degree variety. I'm currently using one on my mountain bike. EA70 think the level is. Cost me about 30£ new from Wiggle.
Bontrager do a 75mm 17 degree stem
Posted : 23/05/2016 10:12 pm
System EX if you want a stupidly proud stem.
Posted : 23/05/2016 10:17 pm
That's not a stem...
[url= https://farm4.staticflickr.com/3880/14436342447_8ae552b79d_o.jp g" target="_blank">https://farm4.staticflickr.com/3880/14436342447_8ae552b79d_o.jp g"/> [/img][/url][url= https://flic.kr/p/nZG2DZ ]IMAG3386[/url] by [url= https://www.flickr.com/photos/takisawa2/ ]pten2106[/url], on Flickr
Posted : 23/05/2016 10:39 pm
http://www.planetx.co.uk/i/q/STPX3DF/planet-x-superlight-team-3d-forged-stem
I could have sworn they used to do a higher angle version, I have an 80mm that I think is 35 degrees, which I use on to raise the front end of my goto bike (now Wazoo) by ~5cm. Really helps my lower back!
Posted : 24/05/2016 5:54 am
Syntace make one - Flatforce, possibly?
Posted : 24/05/2016 6:35 am
Specialized do the comp stem that has a shim so is +/- 22-28°
Shortest is 75mm though. But it's good because you can try different rises without buy more than one stem.
Posted : 24/05/2016 9:02 pm
This is the Syntace one:
[url= https://www.syntace.com/imgserver/syntace/images/5000/5700/5701/picture5701_Syntace.jp g" target="_blank">https://www.syntace.com/imgserver/syntace/images/5000/5700/5701/picture5701_Syntace.jp g"/> [/img][/url]
A bit spendy, though.
Posted : 24/05/2016 9:05 pm
What wiggles said. You need to remember though that as stems get shorter the amount of rise you get by increasing the angle also gets less.
Posted : 24/05/2016 9:21 pm
Which is why I've never understood the length/angle description. It's meaningless unless you know the diameter of the tube used and/or how big the clamp is. Lenght/rise would have been much more useful.
Thank god it's all been kicked into touch with long tt/short stem combos.
Good luck finding one.
Posted : 24/05/2016 9:53 pm
This [url= http://yojimg.net/bike/web_tools/stem.php ]stem position comparison tool[/url] is very handy for figuring out a suitable position
Posted : 24/05/2016 10:25 pm
