shock springs
[Closed] shock springs
[#3124112]
I've used the TFT and mojo spring calculators and one is under 450 the other over. Should I get a 450 or 500?
Posted : 07/09/2011 4:16 pm
I'd trust the TF tuned one personally as it takes the leverage ratio of your suspension design (or nearly).
Posted : 07/09/2011 4:18 pm
Depends if your shock has been tuned for your weight / bike aswell. I got a new spring & sag was fine but it was compressing too much on landings / berms. Sent it off to LOCO who put extra compression damping on and it was loads better.
Posted : 07/09/2011 4:50 pm
the shock has been pushed for the bike and my weight, i've been riding it with a 550 but think I'll change, just not sure which to get (450 or 500)
Posted : 07/09/2011 4:54 pm
The TF one was spot on for me.
Posted : 07/09/2011 6:11 pm
How much sag is your current 550 giving you with no pre-load on it? If you're getting sag of 25% - 30% of travel then you don't need a new spring.
If you're only getting 20%, then get a 500, less than 20% get a 450
Posted : 07/09/2011 6:16 pm
