Shock Size Question
[Closed] Shock Size Question
[#5270805]
Hi
Im looking to get a new CTD shock to match my CTD fork.
Sizing on Santa Cruz website says the shock is 7.875”x 2”.
Will a 7.875x2.25" work or am im gonna cause an issue putting that size on?
Posted : 23/06/2013 8:33 am
The stroke will determine how far the rear and the linkages travel, It could cause fouling on the frame depending on tolerances. The 2" should be available - what frame? You also want the tune for the frame too.
Posted : 23/06/2013 8:35 am
Extra 6mm of stroke will result in 12-18mm extras travel and could result in either the tyre hitting the seat tube of the linkages bottoming out and damaging the frame.
Posted : 23/06/2013 8:36 am
mmmmm...ok thanks guys. Its a Superlight 29er. I wanted to get the shock 2nd hand so was looking around and found one that was what i wanted but alas the wrong size. I wont risk it, will just wait for the correct size to come up.
Thanks Guys appreciate the advice
Posted : 23/06/2013 8:47 pm
