Just got and fitted my new Manitou Minute 29er forks - 80mm travel
anyone recommend a shock pump?
also is anyon eis using minute 29er what sort of pressure are you using for you weight..
was going to set via sag to 12-16mm as per book and go from there.. though that seems to be quite soft
ps got the forks from www.biketart.com (the guys that started off selling helicopter tape) was a very good service
Any shock pump is ok but I like this one
http://www.topeak.com/products/Mini-Pumps/PocketShockDXG
ok ta for suggestion
I've got 90psi in my 120mm version and I'm 13 stone.
I've just picked mine up so I'm interested in this topic just waiting for frame now.
hmm ok i weigh 12 stone - will see what pressure is best..
of course now do i get my swift powder coated white to match the forks and apply the black grey and pink singular decals...
Yeah. That Topeak pump is great for fine adjustments because it doesn't leak any pressure at all when you take it off.
had a fiddle and a few rides now..
settled on an indicated 95psi (me = 12 stone) and 4 clicks from - on the damper adjust and 1/2way on the rebound.
seem to work very well.
