Shimano XTR pedal s...
[Closed] Shimano XTR pedal service Kit, where can I get one?
[#5184414]
CRC list the standard (540 axle bearing) or are they compatible? the photo looks similar to xtr any help appreciated thanks.
http://www.chainreactioncycles.com/Models.aspx?ModelID=28904
Posted : 23/05/2013 9:03 pm
bump.. 😕
Posted : 23/05/2013 9:32 pm
dunno, would like to know as well since my LH )new) xtr pedal is gubbed ( again)
Posted : 23/05/2013 9:35 pm
My LH pedal axle bent, currently with Madison's waiting for warranty sorting
Posted : 23/05/2013 9:48 pm
When I emailed Madison they said the LBS would need to order them. The LBS is currently trying to get me a set of bearings for my M985 XTR pedals.
Radoggair - my LH pedal is good. RH one has knackered bearings (and the bearings are not covered by the warranty). If you want to flog yours for not much I may be interested
Posted : 23/05/2013 9:57 pm
Mine recently went all notchy, took it apart to find the cone on the outside next to the locknut had cracked into 4 pieces. not sure if it's worth a warranty claim but may as well have a go!
Posted : 23/05/2013 10:06 pm
