Shimano Nexus 8-spd...
[Closed] Shimano Nexus 8-spd Hub Gear Shifter
[#1873171]
Do I have to use the horrid standard shifter that looks like it came off gran's shopping bike, or do any other shifters have the same actuation ratio which I could swap for?
Cheers.
Posted : 08/08/2010 4:26 pm
Nexus uses the same actuation as the Alfine, so an Alfine trigger shifter will work.
I use the nexus grip shifter with my Alfine.
Posted : 08/08/2010 4:37 pm
 Del
trigger or twist from shimano alfine or nexus respectively.
otherwise j-tech bar end or versa drop shifters. that's pretty much it.
Posted : 08/08/2010 4:38 pm
Thanks for the responses. The versa costs a few quid!
I take it they are not 1:1 ratio that a normal 8-spd shimano job would work with?
Posted : 08/08/2010 5:39 pm
