Hi,
I'm looking for some assistance with compatibility of current Shimano hydraulic brake levers with old style shimano calipers please. I have Shimano SLX M675 brakes but have broken the right hand brake lever clamp. I cant seem to get a replacement clamp and the only option seems to be to replace the full lever unit. As its an older BL-M675 model that is no longer available I'm trying to establish whether the newer versions (eg the BL-M7100) would be compatible with the old M675 caliper and brake line.
Any help gratefully received!
Cheers.
Yes, all Shimano levers.
M6000/M7000/M8000/Zee/Saint all use the same olive as well. Lower models are BH59 and need a different Olive.
Zee/Saint are both i-SpecB if you use a brake mounted shifter.
Some of the older M6000's are also B and even a few 7000/8000 but not sold new anymore
Awesome, thanks Stevxtc - much appreciated! I dont need to worry about the brake mount shifter as that is mounted separately but good to know. Thanks.
