Shimano Disc Rotor ...
[Closed] Shimano Disc Rotor Question
[#1418634]
Hi
Just got some new Deore 595 brakes delivered, but they didn't come with any rotors, been reading the instructions and it says that I should be looking at SM-RT53 or SM-RT62 rotors, think these are splined, which won't fit on my current hubs. Can I use other rotors ones that bolt on to the hub?
Posted : 16/03/2010 10:32 pm
Yes. Pretty much any rotor
Posted : 16/03/2010 10:34 pm
SM-RT61 would be the 6-bolt equivalent.
excellent. thanks
Posted : 16/03/2010 10:44 pm
Had a look at those RT61's they are fugly.
Merlin have got some XT ones (XT SM-RT75S) they look a bit better, and they have some Ashima Rotors, do you reckon I'll be able to use either of these?
Can't decide on the size of the front rotor either, thinking 180mm at the moment, is that overkill for primarily XC use?
Posted : 17/03/2010 9:51 am
Your deore brakes will chew through the arms of xt ones. the pad is deeper. Not sure about ashima ones.. probably? I've used hayes rotors on deore brakes before and that was fine
Posted : 17/03/2010 10:03 am
Deore 595 pads are exactly the same shape as XT pads so that is not true bikewhisperer. You could use SMRT75 or SMRT76, both are six bolt.
Posted : 17/03/2010 10:32 am
I have XT brakes, SLX and the new Deore M595 and i can confirm that they all use exactly the same pad so you'll have no problem. I use 2 different rotors on the M595's, a standard XT 180mm on the front and a 160mm on the rear using the newer Shimano rotor with the aluminium spider. Both fit fine.
Posted : 17/03/2010 10:36 am
If I put a 180mm rotor on the front do I have buy adapters or spacers for the calliper to handle the larger rotor?
Posted : 17/03/2010 10:53 am
Yes you will need to buy an adaptor if you want to run a 180mm rotor.
Posted : 17/03/2010 11:29 am
 rock
mr tall, how do the three brakes compare?
Posted : 17/03/2010 12:59 pm
