Shimano Dear - Top ...
[Closed] Shimano Dear - Top Swing Front Mech - Cable Advice
[#1387551]
Guys
Ive just put a new Deore Top Swing Front mech on and the cable attachement thing is on the top, where as my older mech (same model, older version) was on the bottom. I just cant see where to thread the cable its confuzzled me like mad.
Anyone help? Pics avail?
Posted : 06/03/2010 12:50 pm
which way does your cable route? from the top or the bottom? Top swing is a sort of mech rather than a cable route.
Posted : 06/03/2010 12:53 pm
Isn't there a sort of pulley that you loop the cable round - its so the same mech can be used top pull and bottom pull.
Posted : 06/03/2010 12:56 pm
I know the two types of swing. My cable cames frim the underneath, i.e under the bottom bracket. I just cant seem to see where a route the cable on the mech :S
Posted : 06/03/2010 1:08 pm
Cable comes up from the bottom bracket area, then over a pulley which is immediately behind the seat tube. The cable sits between a couple of little sticky-out lugs which stop it from falling off sideways. Cable then comes down to the clamp like it would if the cable was top routed.
Posted : 06/03/2010 3:08 pm
