Shimano Centrelock ...
[Closed] Shimano Centrelock - obvious question...?
[#6995822]
Simple one... are the centrelock locknuts generally supplied with the wheelset, the rotors or separately? I've only dealt with these on full-builds before now! Cheers.
Posted : 13/04/2015 12:16 pm
With the rotor: The posher the rotor, the posher the lock ring...
Posted : 13/04/2015 12:18 pm
Ok, cool. Then how would one know if they will be supplied with the lockring that suits QR (using a cassete tool) or 15mm (using a BB tool)?
Posted : 13/04/2015 12:27 pm
Look in the packet 😉
A cassette-tool lockring came with a RT67 that I bought very recently.
Posted : 13/04/2015 12:42 pm
[url= http://forums.mtbr.com/brake-time/shimano-centerlock-20mm-lock-ring-problem-508451.html ]This may help...[/url]
Look for the post by Ronnie.
The rotors are supplied with lockrings for QR use. Shimano hubs or wheels other than QR hubs are supplied with a (different) lockring for the relevant axle standard.
If you want a 15mm lockring it won't come with the rotor, you either need to buy it as a spare part of find the one which came with the wheel or hub. If you're buying a new hub/wheel, at least from Shimano, it'll be supplied with that.
Posted : 13/04/2015 12:44 pm
