Shimano Campag comp...
[Closed] Shimano Campag compatibility
[#210606]
Hi there, think i have done something stupid, so can anyone help me out. This road bike lark is way more complicated!
I bought a set of Campagnolo Khamsin wheels, which I want to put on my Gioant OCR 2. At the minute it is running Shimano Tiagra 9 speed groupset. I know my cassette doesnt fit on the campagnolo freehub so I was going to buy a campagnolo cassette and then run my shimano groupset.
However after talking to some unhelpful bike shops (naming no names!) I was told that there is no compatibility whatsoever and you would be lucky to get more than 2 or 3 useable gears out of it. They said the spacing is different. I figure how much space is there to fiddle about with, surely the differences are so minimal (seeing as each of the 9 cogs need equal spacing) that i would just have to change the upper an lower limiter screws rather than throwing all my shimano stuff away.
I hope they were trying to dupe me out of money, because I can feel my bank balance taking a hit already!
Thanks for any help you can give
Posted : 13/01/2009 12:03 pm
have 9 speed campag sti's with shimano deore rear mech over either a shimano or campag cassette on my cross bike. No probs here. spacing is different,but in the order of .003mm or something stupidly small.
Posted : 13/01/2009 12:13 pm
The spacing between cogs in different - think 9 campy cogs/spacers is actually wider than the Shimano equivalent. If you want to see if you could live with it, give the adjuster on your mtb rear mech a couple of turns and see how long before you go mad with the grating of cogs just slightly off from the chain....
Its a small difference but enough on such a delicate setup to be annoying at the least.
Having said that I've run a Shimano cassette on an otherwise Campy road bike for a while before I went the whole hog - the low gear would slip a bit and I'd always have a tiny (maybe imaginary) feeling the other cogs just weren't meshing properly. There are various tweaks you can do - can't remember the websites.
Posted : 13/01/2009 12:24 pm
Im confused now as to what to do. I have been looking for a shimano freehub that will fit the wheelset, but no luck as yet
Posted : 13/01/2009 12:53 pm
 aP
Go to a proper bike shop - I'd suggest Condor and ask them about getting a shimano spline freehub for your wheels.
Posted : 13/01/2009 1:03 pm
there are places that do shimano spaced cassettes to fit campag hubs.
Might be easier to find someone with the same problem in reverse and swap wheels, though?
Posted : 13/01/2009 1:07 pm
Somehow I doubt you'll get a Shimano freehub for a set of Campag wheels! I have the same wheels on my Pompino and although cheap, they seem to put up with a good lot of abuse!
One thing that may be possible, Campag cassettes come as a set of individual cogs and spacers, so if you can find the spacing for a Shimano cassette, I would imagine it would be possible to change the Campag spacing to suit...
Other than that, someone in the US makes a widget that allows you to mate Campag and Shimano, but the name escapes me at the moment...
Posted : 13/01/2009 1:12 pm
 aP
I know for a fact that Campag Neutron, Eurus and Shamal Ultra wheelsets can be supplied with Shimano spline freehubs.
Posted : 13/01/2009 1:15 pm
A lot of Campag wheels are now available with Shimano freehubs, Campag (eventually) realised it was the only option for people who wanted to run a proper groupset but had some strange reason why they wanted to buy overpriced Campag wheels. 😉
Campag/Shimano compatibility is a difficult one, sometimes things work near perfectly, other times they won't even come close, it varies between groupsets and components. As a general rule though it'll never work as well as a full Shimano or a full Campag set-up.
Personally I'd sell the wheels and buy a set of Mavics or Shimanos and just have done with it. Or go and buy a Shimano-splined Campag freehub and swap them over.
Posted : 13/01/2009 1:22 pm
if you can get a shimano freehub to solve any issues easily - other wise get a campag cassette and swap the spacers inside for shimano spacers (you might have to do a little filing on the splines to fit) - best for second look at micarms thread reply
Posted : 21/01/2009 10:34 pm
hi, have a look here
http://www.totalcycling.com/index.php/product/SPC_FREEHUB_S10.html?action=currency&id=GBP
you can get 8/9 speed as well
they also fit fulcrums
Posted : 16/03/2009 9:23 pm
this might be work a look
http://www.highpath.net/cycles/cassettes/01.html
Posted : 16/03/2009 9:35 pm
