Shimano brakes, shi...
[Closed] Shimano brakes, shimano rotors?
[#4661142]
I have the new style shimano XT brakes with the finned pads and am currently using 183 hope floating rotors. Does it matter that the rotors are a different brand to the brakes. I have never thought it an issue however i read somewhere the other day that like brand products will work better together. Would it be better to switch to the ICE rotors???
Posted : 17/12/2012 8:45 pm
 Kuco
Got older style XT brakes but have been using Hope rotors for over a year with no issues.
Posted : 17/12/2012 9:29 pm
the brand doesn't matter, but the size does. I think if you use shimano brakes and adaptors it will want a 180mm disc.
I just got cheap ones of ebay - seem pretty good:
http://www.ebay.co.uk/itm/180mm-7-Inch-Disc-Brake-Rotor-for-SHIMANO-6-Bolt-IS-/140897375219?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item20ce2353f3
Posted : 17/12/2012 10:07 pm
ive got the same set up as the op. no problems with it but am using the hope 183 adaptor.
Posted : 17/12/2012 10:41 pm
said the man from the marketing department...
Posted : 17/12/2012 10:55 pm
Some rotors don't like some brakes (mainly the really lightweight KCNC and alligator style) but most other should work well together as long as they're the right size.
Posted : 17/12/2012 10:59 pm
I have some hope Saw Rotors and they are slightly thicker which doesnt do well with Shimanos.
Posted : 18/12/2012 10:23 am
Ran XT Brakes for ages with Hope 183 rotors, no issues. Used Avid 185 adaptors - oddly, I was given a Hope 183 adaptor and tried it, but found that the disc slightly contacted the caliper with it.
Posted : 18/12/2012 10:32 am
Size does matter - thickness and diameter. Other than that you will be fine.
Posted : 18/12/2012 10:33 am
