Shimano brake compa...
[Closed] Shimano brake compatibility/Post mount options
[#11044853]
I have a Genesis Croiz de fer 2014 which I believe has post mount disc brakes. I am looking to upgrade them to hydraulics but most of Shimanos road range now seems to be the more modern flat mount.
I have a good deal on some R7020 hydro-disc STI units using the BH90 cable. If I find a Shimano MTB brakes that use the same cable, would they be compatible or will the master cylinders be different sizes?
e.g.
https://www.bike24.com/1.php?content=8;product=287637;menu=1000,2,15,117
https://bike.shimano.com/en-EU/product/component/deore-m6000/BR-M6000.html
Posted : 10/02/2020 11:42 pm
Croix de Fer has IS mounts. A shimano mtb caliper will work fine with the R7020s, you'll  just need some post/IS adaptors.
Posted : 10/02/2020 11:57 pm
 cp
I use mtb calipers on both sets of road levers (R505 and R8020) and they work perfectly.
Posted : 11/02/2020 10:31 am
MTB calipers work fine, just make sure the hoses are compatible. Different fittings on the road levers too, so if you buy the levers and hoses seperate you'll need a fitting kit (unless you buy the road version of the hoses)
Posted : 11/02/2020 11:47 am
Anyone have a link to the different fittings? The road just require an olive and barb and tightened in to the port, it looks like the Deore (for example) caliper has a similar inline fitting rather than a banjo fitting?
And I presume that while "it works" it won't be officially supported by Shimano, right?
Posted : 11/02/2020 12:24 pm
