Shifter compatibili...
[Closed] Shifter compatibility
[#5649164]
Will a 10 speed SRAM X7 shifter work with a 10 speed Shimano 105 derailleur? Or maybe that should be, will it work well?
Posted : 30/10/2013 8:24 pm
No, don't think it'll work at all.
Posted : 30/10/2013 8:27 pm
Simple rule!
Shifters and rear mechs have to be the same makes!
And the same number ratio's!
You can mix road and mountain stuff but the same rule applies!
Posted : 30/10/2013 8:33 pm
In my skim read of thread titles, I thought this was going to be about toilet seats or similar 😳
Posted : 30/10/2013 8:35 pm
Not even that neat - 10 speed Shimano MTB stuff is different to road, which is cross compatible with 9/10. SRAM 10 speed is interchangeable though.
Posted : 30/10/2013 9:50 pm
So you could mix and match 10 sram and Shimano on road stuff?
Posted : 30/10/2013 9:53 pm
No, you can use SRAM XX mech on a road bike if you want. There are 4 rear mech pull ratios:
1) Shimano all 7/8/9 plus 10 speed road
2) Shimano 10 speed MTB
3) SRAM 9 speed
4) SRAM 10 speed road and MTB
As long as your mech and shifter match you'll be fine.
Posted : 30/10/2013 10:38 pm
