seized cable barrel...
[Closed] seized cable barrel adjuster
[#4276221]
how best to deal with?
It's (alu) in a welded on stop on the (alu) down tube. can't get a std length drill bit in straight but may look for an extra long one. Then tap out.
Posted : 19/08/2012 8:46 pm
Plusgas?
Posted : 19/08/2012 8:55 pm
Would this kind of thing help?
A stumpy 90 degree drill adapter.
Posted : 19/08/2012 9:08 pm
Leave it as it is and use an inline adjuster.
Posted : 19/08/2012 9:09 pm
 LsD
Mallet/Shards......etc.....
sstu...I'd love to but the head has snapped off.
Posted : 19/08/2012 9:12 pm
A stud extractor should get that out no problem then.
Posted : 19/08/2012 9:16 pm
Not where it is.
Posted : 19/08/2012 9:17 pm
Not where it is.
Sirly there's room to get an easyout in and turn it with a small spanner?
Posted : 19/08/2012 9:29 pm
leave it ull be rate
Posted : 19/08/2012 9:32 pm
maybe sstu...between it and the head tube?
Posted : 19/08/2012 9:33 pm
full length outer and just ziptie the cable to the "stump"
Posted : 19/08/2012 9:34 pm
Grind the easy out down and turn it with molegrips then.
Come on Al.
Use your mad construction skillz in a different way. 🙂
Posted : 19/08/2012 9:36 pm
TBH I am thinking an M5 thread bolt with a 1.5mm hole, that's say 1mm solid cheap aluminium, it needs drilled out, esp given how easily the head snapped off, an eazy out will just cut it up.
Posted : 19/08/2012 9:40 pm
I bet the adjuster was already cracked before you tried to turn it though.
Posted : 19/08/2012 9:43 pm
agreed.
How do you rate my chances re. comeback frmo ebay seller? TBF he's already refunded me 15% for the scratched condition of the bike....
Posted : 20/08/2012 1:28 pm
Had a similar thing on a road frame prepping it for powder coating - tried to take out the down tube barrel adjusters and they both snapped off. Did what you are suggesting - drilled out the stuck adjuster and thread in the boss and replaced with the barrel adjuster parts of this set:
http://www.sjscycles.co.uk/modolo-morphos-down-tube-stops-set-prod20642/
All plastic (bar the retaining nut), been sound since, and should be no future issues.
Off course, I had the destinct advantage that I was re-coating the frame, so a few marks from the drill chuck trying to get the bit straight could be covered up after the event.....
Posted : 20/08/2012 1:36 pm
Got a picture?
Posted : 20/08/2012 1:37 pm
I've been there before.....
I used the tang of a small rat tail file.... heated up and bend the end of the file to a right angle(keep the end in a vice to avoid over heating it as you want it to keep its hardness)
hammer in gently .... turn gently..remove ....... repeat...
you could always try the same with a small torx key...
Posted : 20/08/2012 1:49 pm
had the same problem got a shake drive for drill and used hexagonal shanked drills. I used several small drills and finished of with 4.8 the thread remaining just screwed out as the drill emerged out of the other side and i was able just to screw new adjuster in
Posted : 17/05/2013 4:17 pm
