seatpost shims - wh...
[Closed] seatpost shims - why not?
[#5276930]
Is there any reason not to use one of those USE shims to shim a 30.9 seatpost to 31.6mm?
ta!
Posted : 25/06/2013 9:17 am
if the shim doesn't extend below the top tube/seat stay/seat tube junction by a few cm would be the main one for me.
I had to source and extra long one (120mm) when I was shimming a post for my Titus Fireline.
My Scott CR1 came with explicit instructions not to use a shimmed seatpost.
Posted : 25/06/2013 9:20 am
Used 1 for the first time on the weekend. I tightened the quick release to its normal tension but the seat post would slip a few centimetres every 20 minutes. This was over fairly rugged terrain.
My quick release needs an hex key to tighten it properly so i couldnt be bothered on the trail. Will tighten it slightly and see if it still slips.
Posted : 25/06/2013 9:28 am
pembo6 - try some carbon paste between shim and seatpost.
Posted : 25/06/2013 9:29 am
Thanks wwaswas
Posted : 25/06/2013 9:34 am
mine works fine though it is 27.2 to 31.6
Posted : 25/06/2013 9:39 am
mine works fine too 27.2-31.6
Posted : 25/06/2013 9:44 am
FYI the Superstar shims are slightly longer then the USE shims, only by ~15mm but might be important.
Posted : 25/06/2013 10:04 am
30.9 to 31.6 USE seatpost shim in use here on a Reverb no issues to report .
Carbon paste was used so the torque needed wasn't excessive
Gives me frame options in the future
Posted : 25/06/2013 10:19 am
I've used one without problems but I'm sub 60 kg which may well be a factor.
Posted : 25/06/2013 11:00 am
I'm rather north of 60kg (100kg) and no issues 😀
Posted : 25/06/2013 11:06 am
I'm using a 27.2-29.8 USE plastic one in my P7 with qr seatclamp and have no problems with slippage despite being over 90kg. Used a plastic one as the original alloy one corroded into the seatube and I had to hacksaw it out.
Posted : 25/06/2013 11:09 am
