Hi
i broke a frame (seatpost tube)even though I respected the minium insertion of it, as I prove them with photos
This is their reply:
"They have looked over the information you have sent and because you have used a shim the seat tube has not been supported correctly"
Note that the shim is a 4" USE one
What dou you think???
Did the shim come below the min insertion mark?
Of course
Pace?
Issue is whether the shim went below the junction. Extended seat tube may mean it didn't.
Scott specifically say warranty it's void with use of a shim in their carbon frames.
After my brother cracked his dream Kona Hei Hei frame when he used a shim on his USE seatpost I decided I'd never use one myself (he doesn't either).
No seatpost is worth cracking the frame!
Unfortunately I don't think many (if any) companies will warranty seat tube damage where a shim has been used. I suspect there is probably quite a variable thickness of shims (poor tolerances) and the seatpost/ seattube contact is less consistent and potentially subject to more bending forces than a seatpost only, even if the shim has a deep insertion. Can't explain this well but that would be my guess...
and why they don't say that in the warranty or the owners manual?
That's a question to put to the company if it isn't clear where they state their stance on seatpost shims. Most companies tend to be clear on this.
