Seat post shim - As...
[Closed] Seat post shim - Asking for trouble?
[#11205398]
Never had a shim before, are they to be avoided if possible?
Ordered a cheap Crank Brothers dropper but failed to notice it's 30.9. Bike is 31.6, damn it!
Shim (100mm) can be had for £10 ish. Will be a 170mm drop post with probably another 30mm extra post out of frame so a fair length.
Can replace for a brand X for another £40 in the correct size.
Posted : 22/05/2020 11:33 am
I ran 30.9 dropper in 31.6(shimmed) no issue
Posted : 22/05/2020 11:50 am
Used them for years, in various configurations. Zero problems.
Posted : 22/05/2020 12:10 pm
You'd be surprised at how many frames come shimmed already.
Posted : 22/05/2020 12:12 pm
Ran a 30.9 dropper post in a 31.6 frame shimmed for a while, used carbon grip to make sure i didn't need to torque it up to tight just in case that affected the dropper working but never had any issues
Posted : 22/05/2020 12:15 pm
Shim shimmy it is. Cheers guys. Should probably be more worried about the Crank Brothers post.
Posted : 22/05/2020 12:38 pm
Been running a Cane Creek shim for years, just does what it's supposed to, zero drama. It's supposedly a good quality one though, with a good texture to it to about slippage. I guess that makes a difference.
Having a plastic bushing in between the seat tube and seatpost is not as weird as mountain bikers often think. Loads of mechanical equipment always have a polymer bushing of some sort in similar assemblies
Posted : 22/05/2020 3:08 pm
USE shim will do the job.
Posted : 22/05/2020 10:57 pm
As above shims in use at least 30 years.
To note though is that you can get slippage, especially with the USE nylon ones. Which might promote you over tightening, and I dont know if that would damage the mechanism of the post, but I dont think it would do it too much good. Possibly deform it to prevent it from working.
Posted : 23/05/2020 2:41 am
