Schwalbe's Pro...
[Closed] Schwalbe's Procore
[#6312263]
I've probably missed something fundamental, but is this just a narrow tube inside a conventional tubeless setup?
In other words, could I replicate most of the benefits with a 1-1.5" tube and a second valve hole?
Posted : 02/07/2014 4:14 pm
You'd presumably need something tougher than just a normal inner tube or it would just stretch, overinflate and quickly burst.
Posted : 02/07/2014 4:15 pm
Thought about that, sure you couldn't inflate it to 85psi, but don't forget that the pressure in the tyre will help control the expansion of the tube.
Posted : 02/07/2014 4:20 pm
It's really the bicycle equivalent of a 'bead lock' something that has been around for donkies in the off-road/heavy haulage & Military world.
It is more like having a 200g tyre inside.
Posted : 02/07/2014 6:22 pm
Not really if it's an 85psi inner and a 15 psi outer. You'd do better just to fit a tubular tyre as the inner if you wanted to bodge it.
Posted : 02/07/2014 7:26 pm
