Saint Hydraulic Hos...
[Closed] Saint Hydraulic Hose, just checking compatibility...
[#3673570]
Just to check I'v worked this out right, I'm running Saint M810 Hydraulic Brakes that are perfect, except I need to replace the hosing on them.
I've been quoted from an LBS £25 for a kit per brake before bleeding, so £50 total.
I presume as it's only the hose changing, all my connecters etc can be moved across, so something like:
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=4422 ]This here[/url]
Bought in the right quantity will do me just fine?
(Obviously brakes will still need to be bled)
Thanks!
Posted : 13/02/2012 6:00 pm
You'll need olive(s)and fir trees as well as the hose if you've got straight connectors at both ends, if you have a banjo at the caliper then it'll be factory crimped onto the hose and you'll need to buy the full kit.
Posted : 13/02/2012 7:57 pm
