RX-8 Uno Chainrings
[Closed] RX-8 Uno Chainrings
[#6784359]
Anyone run one?
I've heard they creak under load?
And Middleburn have tried to resolve the issue with a revised design, but have not been sucessful
The Uno rings are also bloody expensive (£70 odd!)
Posted : 16/01/2015 9:11 am
Middleburn's anyone?
Posted : 16/01/2015 2:59 pm
RX-8 creaking ? might be the drivers wrist.......
If you mean RS-8's then I run an UNO setup on my SS . Not a sound out of them I can hear the grit in the chainlinks but no the Crankset is rock solid.
Posted : 16/01/2015 3:45 pm
😯 Ah, yes, I do mean rS-8...
Great to hear as I've just gone through the pain of ordering one to use SS
Wished I had known the RS-8 has a different offset to the square taper stuff I used a while back so all that stuff - including the tools to get the lockring off is all different...
How long have you been running that set-up? How durable is it proving to be?
Posted : 16/01/2015 3:57 pm
Only about 4-5months I recon but it's used for the off road commute to work and being a rigid SS it gets left covered in crap i'm not the lightest of chaps either but yeah crankset is rock solid.
Posted : 16/01/2015 4:09 pm
Good to hear.
I've ran the square taper cranks on and off and have always thought them not only well stiff enough, but good lookers too
I suppose I'm more interested in the Uno ring and how that has been for you - tooth wear particularly
Posted : 16/01/2015 8:19 pm
Well when I say they're rock solid I mean the chainring / crank interface, no creaks or flexing.
I have a hardcoat ring I'll get some pics to show any wear on 'morrows ride if I remember.
Posted : 16/01/2015 8:26 pm
Oh thanks
Posted : 16/01/2015 8:35 pm
Right here you go.
Not too bad considering I'm running a sloppy half link too.
Posted : 17/01/2015 1:22 pm
Blimey - that's quite amazing for ~6 months use
I used an Uno for a while and it got well worn - I guess that was running a 1x9 though so having a straight chain line is obviously much much better
Thanks for posting
Posted : 17/01/2015 1:44 pm
