Running normal Hope...
[Closed] Running normal Hope hubs as SS
[#5638263]
I'm after some new lighter wheels for my 29er (Crest on Pro Evo).
Will this combo be pantaloons if I run it as SS?? As I'm concerned about killing the freehub body.
Posted : 27/10/2013 9:21 am
If you're buying new I'd reccomend the steel freehub body option if you plan to run ss.
Otherwise make sure you buy a wide base SS cog
Posted : 27/10/2013 9:25 am
Just use a wide body cog like on-one groove armada or the surly wide body !
Sweet! Cheers chaps 🙂
Posted : 27/10/2013 9:30 am
Also have a look at Superstar Components: wider than On-One's and £7.99.
Posted : 27/10/2013 10:46 am
 core
Don't the wide base cogs limit your amusement to get a good chain line?
Posted : 27/10/2013 10:55 am
Are you ever going to run the hubs geared? If not I'd get the ss hubs + qr adapters
Posted : 27/10/2013 12:01 pm
Have Hope hub and Surley cog with Onza spacers. Chainline is perfect. Mine is on a track dropout IOID and use QR with the chaintug bolts.
Works fine. The ss/trials hub isn't that different, but I wanted the flexibility to use the wheels on other bikes.
Posted : 27/10/2013 12:09 pm
Use a wide base cog and with Velosolo spacers you can perfect your chainline to within a mm.
Posted : 27/10/2013 12:10 pm
