Running Mavic XM719...
[Closed] Running Mavic XM719's tubeless
[#5339548]
Will a superstar rim strip and valve suffice or do I need the stand kit?
Also any one got experience of smorsgasboard tubeless on these rims?
Thanks
Posted : 17/07/2013 9:53 am
I always used proper rubber conversion strips with mine.
Posted : 17/07/2013 9:57 am
Used insulation tape on TN719's works perfectly.
Posted : 17/07/2013 10:01 am
Using Stans rimstrips on my XM719s. Used Specialized 2bliss and Maxxis standard single ply tyres successfully.
Posted : 17/07/2013 10:14 am
Stans Yellow Tape, Valves and Ardent EXO's up first time and holding fine
Posted : 17/07/2013 10:15 am
So it's worth a shot 🙂
Posted : 17/07/2013 1:53 pm
I hope so as I just bought the superstar stuff myself so I hope it works:)
Posted : 17/07/2013 2:18 pm
I've used rimstrips, but for best results I use layers of electrical tape and Joe's tubeless Schraeder valves.
Works a treat.
Posted : 17/07/2013 2:38 pm
Anyone successfully used any of the following tyres:
conti X-King protection tubeless ready
Nobby nics tl ready
Racing Ralph tl ready
Posted : 21/11/2013 11:17 am
I'm using Nobby Nics, one tubeless ready, the other not.
Both seem fine so far with SS yellow tape on Mavic rims.
Posted : 21/11/2013 11:20 am
3x loops of high quality electrical tape worked fine for me on xm719's
Posted : 21/11/2013 11:42 am
I tried just yellow tape, it worked til about the third corner then the tyre rolled off the bead. BMX tube almost worked, I reckon I could have made it ok with a bit more work, or maybe different tyres but I just got fed up with the hassle of it all.
Posted : 21/11/2013 11:50 am
Just got my nobby nics out...there not TL ready!!
Will they still work tubeless? what's the difference between a TL ready tyre and a non TL ready?
Is it just the bead and no holes in the carcass?
Posted : 23/11/2013 4:21 pm
Why in stans video do they say drill the first valve hole only? I don't see the point as the valve on the standard rim strip is the same thickness from top to bottom..So why so does that hole need to be widened?
Posted : 23/11/2013 4:49 pm
