07 revelations lower leg negative nut, the hollow one that goes on the bottom of the dual air side will not tighten on the shaft because the shaft keeps turning. Threads on a bit then no more. What am I doing wrong?
Are the internal bumpers seated correctly, mine didnt tighten when they werent??
Compress the fork a bit and try again.
As above, but also look in the hole at the bottom of the fork and see if the thread is lining up properly. If not, just use a small allen key to wiggle it into place.
Not bumpers, i have 5 cm of threaded bolt showing out of bottom, but nut tightens on to clear bolt and then tightens no more as the shaft turns. locating the other non air bolt side is fine.
Just removed and pressed down bumpers to check seated ok, still 🙁
I've done this loads of times before - honest guv.
I meant compress the forks and tighten the nut at the same time.
forks compressed to zero travel - still turns shaft and nut 🙁
nut is not cross threaded.
Come on hive mind - it might not be as interesting as Picolax or Lazytown, but please help.
you have got air in the positve chamber yes? (else there is no pressure against the rod to hold it still)
oops - pumping now
Hurray - Viva la STW. 🙂 Skippity skip skip round the kitchen.
Many thanks retro83 - Will remember that trick - funny how no service guide or videos mention this.
well, check it actually fixes it before you get too excited! 🙂
Yes - jobs a goodun.
Now to change from remote poplock to leg lever via PP's guide - But will it be done before Mrs Wally sees the bikerepair centre/kitchen?
