RS Revs - travel ke...
[Closed] RS Revs - travel keeps creeping down???
[#2910483]
Hi,
I put the recommended pressures in, 120psi and all's great at 150mm for a bit but mid way through the ride they seem to creep down to 130mm.
I'm guessing i need more or less in the negative but i'm not sure which, any advice appreciated
ta
Posted : 03/07/2011 6:48 pm
sounds like a dodgy seal between +/- air chambers imo pulling travel down. i would get em checked where you bought them from IF you are the original owner, if not a seal kit will sort it
Posted : 03/07/2011 6:51 pm
It's a common seal issue with the air ones, something to do with the seal on the negative air chamber. I can't remember if it is leaking into or out-of the negative chamber. Try pumping air into the negative and see if the travel comes back.
Posted : 03/07/2011 6:52 pm
thanks, i bought them s/h so it's looks like new seals then
ta
Posted : 03/07/2011 7:04 pm
i can't find that seal to buy, anyone know the size?
Posted : 03/07/2011 8:00 pm
