RP23 shock conversi...
[Closed] RP23 shock conversion
[#4274023]
Got a RP23 shock with the pro pedal lever on a Top Fuel but the rear suspension is so good their is no (hardly) any difference between Pro pedal being on or off. Anyone know if you can get it modified so the lever is either pro pedal or fully locked out.
Will be ringing TF Tuned on Monday but thought I would get some insight before I ring them.
If the answer is yes, what would happen if you forgot to flick it from fully locked and you hit a large bump, would it automatically blow through or what have you?
Cheers.
Posted : 18/08/2012 7:32 pm
Im pretty sure you can get the compression tuned to soft, medium or firm for when pro pedal is on. My RP2 is set to firm so when i turn pro pedal on its almost locked out for my weight.
But doesn't the RP23 have 3 pro pedal settings
Posted : 18/08/2012 7:39 pm
yep it has 3 settings mine is at tf as we type
Posted : 18/08/2012 7:41 pm
It has 3 dial settings in front of the lever and a ratcheted dial for rebound behind that. Lever flicks one way or the other.
Posted : 18/08/2012 7:42 pm
yes the 3 dial settings are your pro-pedal 3 being the hardest
Posted : 18/08/2012 7:44 pm
