Rockshox revelatio...
[Closed] Rockshox revelations 150 down to 140/130 ?
[#7793678]
I have some Revelations on a bike and wanting to reduce them down from 150 to 130/140 can I do it the same as Pikes with the tokens ?.
Posted : 27/04/2016 12:43 pm
What year revs? 2015 solo airs require a new air shaft to drop / raise the travel. I have a 2015 140mm air shaft i can sell you, unused. Loco & the like can cut your current air shaft down to whatever travel you wish (eg 137.5mm).
Posted : 27/04/2016 12:49 pm
They're 2015's,I thought it was a straight forward token job, similar to Fox,I wanna let my 11yr old ride it, so need to lower it a bit, but want to have the option of going back up,so didn't really wanna butcher them....so if that's what it takes he'll have to learn to ride !,lol,thx again.
Posted : 27/04/2016 1:05 pm
Pike tokens don't adjust travel, they reduce air volume to change the spring rate, making it more progressive.
Air shaft swap is the only way unfortunately.
Posted : 27/04/2016 1:53 pm
if its air cant you just put some spacers under teh top out spring?
i know nothing about these forks by the way...
Posted : 27/04/2016 1:56 pm
