So I'm installing 4 bottomless rings on my monarch plus rc3 debonair shock however am unsure which "sector" to slide them onto. I'll try attaching a photo to help me explain my problem but there's 3 portions under the air sleeve I've removed.
Going from the end with the shaft with the sag markings on there's an o-ring and then a small section, another o-ring then a smaller section but with only a small raised ridge then a larger sector moving onto the final o-ring and then you're at the top of the shock with the rebound adjusters etc.
I assume placement of these affects different things but can't find much online as yet as to where to place them. Many photos I can find have them all over.
Cheers for any help!
As per the photo above, push/fit them as far up,as they'll go under the piggy back chamber.
Set sag as normal and keep the air pressure the same when trying various numbers of bands.
Cheers for the help, I'll try it out tomorrow
