Rock shox Sids - 80...
[Closed] Rock shox Sids - 80/100 adjustment??
[#734674]
I'm thinking of splashing some cash to buy some new XC forks. With the 09 Sids, can you switch between 80 and 100 mm buy just altering the internals as with previous models?
Posted : 25/07/2009 9:44 am
No. You buy either the 80mm or 100mm version and stick with it as far as I can work out.
Posted : 25/07/2009 9:48 am
Hmmm I dunno, looks like you can actually, I just found this:
The Rock Shox SID Race is preset at 100mm of travel, though the All-Travel spacer can be swapped to bring it down to 80mm. There is a Dual Air Spring, separate chambers for positive and negative inputs, that adjusts via two Schrader valves.
Posted : 25/07/2009 10:01 am
Yes, there's an all travel adjust spacer to change the travel
Posted : 25/07/2009 10:10 am
Ah ha!! I am after a pair of these myself and have noticed that at times either the 80mm or 100mm can be significantly cheaper to buy from some shops so I presumed that they would be different.
Had a blokes Reba SL in a mates shop to be changed from 80 up to 100mm by adding a spacer so it might be the same idea.
His Reba SL came as 80mm standard with some plastic spacers in the box.
Posted : 25/07/2009 10:19 am
Right cheers, I thought it'd be odd for rock shox to stop making them adjustable.
Posted : 25/07/2009 11:12 am
They use a 20mm spacer on the spring-rod. Is a 15 minute job to take it out or put it in, hardest bit is finding a socket that fits over the -ve air valve. Manuals on RS site are superb, makes it no bother to do.
Posted : 25/07/2009 11:25 am
Cheers Dougal
Posted : 25/07/2009 11:49 am
