Rock Shox Reverb Se...
[Closed] Rock Shox Reverb Seat Post
[#4747144]
Just recently took delivery of a reverb with the silver collar (CRC). The unit goes up and down at the touch of the lever and everything feels fine, but if I pick the bike up by the seat the unit will extend to the max?? A mate said his doesn't do this, so what's wrong with mine?
Posted : 13/01/2013 10:20 pm
Iirc they all do this? Takes some effort though.
Posted : 13/01/2013 10:22 pm
Mine does it... I started a very similar thread.
[url= http://singletrackworld.com/forum/topic/whats-happened-to-my-reverb ]clicky[/url]
almost max pressure made it better.
Posted : 13/01/2013 10:23 pm
Cheers guys. It's damned annoying! just read the thread, I'll put more air into it and see what results I get?
Posted : 13/01/2013 10:31 pm
Yeah they do all do this but all three I've had on different bikes have only done it with a very firm tug.
Posted : 13/01/2013 10:34 pm
Read the instructions. Picking the bike up by the seat trashes the seals and invalidates the warranty.
Posted : 13/01/2013 10:35 pm
Rockshox saying it won't hurt the post here:
skip to 1.54
Posted : 13/01/2013 11:15 pm
Bit useless for doing many uplift days then depending on the method used to secure the bike? I know glencoe chairlift uses the saddle.
Posted : 13/01/2013 11:19 pm
why? Just pop the saddle up to full height and then stick it in the chair lift.
Posted : 13/01/2013 11:23 pm
Fort Bill is a saddle lift also. But if your riding uplift do you really need a dropper in, running the risk of trashing it. I've got a standard post/seat which takes minutes to swap, keeping the dropper for the days/rides I need it and tend not to use it at all in the winter, it's to precious! (And mine does it aswell).
Posted : 14/01/2013 12:57 am
whenever I have ridden Glencoe I've put the frame in the chairlift, not the saddle. So you don't have to use the saddle.
Posted : 14/01/2013 11:11 am
I picked mine up too often by the saddle. It creates a vacuum and pulls air in. Needs bleeding shortly after. Only pick the bike up if by the saddle if the post is fully extended and you'll probably be fine, why have a dropper in on an uplift day? If you come off the reverb will be likely to get damaged. Put your old post back in
Posted : 15/01/2013 8:47 am
