Roadie assistance r...
[Closed] Roadie assistance required
[#3520292]
I'm changing a few parts and need a bit of advice.
Drivetrain:
I have 10 sp Centaur set up. I will replace the crank with an 11sp Chorus crank which should work fine with the remaining 10 sp set up.
Can i use a 11sp rear mech with 10sp chain and cassette and an 11sp crank?
I currently run a 34/50 compact crank. What differences will i notice with a double 39/54 cranket? Will the double work with my 10sp chain/casette or do i need to make any changes?
Wheelset:
I have open pros on campag hubs. These are about 3 yrs old. Have been used for commuting and occasional weekend training rides. Will probably be doing more road based training this year and the commuting. Can you recommended a decent light wheelset for training and commuting.
A few questions raised hopefully the STW collective has the answers!
Posted : 03/01/2012 11:02 pm
I think no.
Double chainset? Just ups your gearing and brings the range in tighter. Might have to lengthen the chain, but will probably be ok.
A nice light wheelset for training and commuting? That would be open pros on hubs of your choice then.
Posted : 03/01/2012 11:05 pm
With the double you might find very steep hills harder (but you'll be given more respect)
A nice light wheelset? I've just bought a pair of Velocity Aerohead rims on Pro 3 hubs from JRA, they feel spot on. Somewhere around 1500g or just over I think, apparently a bit better than Open Pros
Posted : 03/01/2012 11:09 pm
lol 🙄
Posted : 04/01/2012 8:56 am
good luck with a 54t outer ring is what i'd say.
unless you plan on time trialling, the move from a compact 50t to a double 54t will be large
Posted : 04/01/2012 9:47 am
