road tyres.....what...
[Closed] road tyres.....what pressure
[#3870479]
25c tyres, what PSI do you run?
Posted : 14/04/2012 4:51 pm
110/100 wet/dry front, 115 rear for me.
Posted : 14/04/2012 4:53 pm
100, bit less, bit more depending on conditions 90-105
Posted : 14/04/2012 4:54 pm
 aP
Posted : 14/04/2012 4:58 pm
110 front and rear on a 23c.
Posted : 14/04/2012 5:03 pm
80-100 depending on conditions and when I last pumped them up.
Posted : 14/04/2012 5:48 pm
 Kuco
About 100
Posted : 14/04/2012 5:51 pm
 MSP
90 front 100 rear and I am heavy.
There is a lot of BS myths about road tyres and pressures, usually based on what works on the track.
Posted : 14/04/2012 5:56 pm
110 both on GP4's.
Posted : 14/04/2012 6:10 pm
Surely you inflate them to what they say on the Tyre?
Or Am I being Gallactically Blonde?
Posted : 14/04/2012 6:13 pm
85 front 95 rear on 25c tyres. I weigh 150lbs.
Posted : 14/04/2012 6:16 pm
Depends on your weight dosnt it.
I usually run about 100psi for the roads around here, but on lovely smooth roads ill go higher.
Posted : 14/04/2012 6:19 pm
Proper lazy pump them up to about 100 but only do it now and then.
They get down to 60-70 Normaly and does not seem to notice.
Just try a few and see what happens
Posted : 14/04/2012 7:38 pm
That's a good link for the Michelins, cheers... I'm using Optimums at 100psi so I guess I should try dropping it a bit.
Posted : 14/04/2012 7:41 pm
135psi in my ultremos
Posted : 14/04/2012 7:56 pm
I'm sure this was asked at the Pro Tour City centre jobbies. They said about 100/110 or 90 in the wet.
Posted : 14/04/2012 8:14 pm
120 in my tubs,100 in the clinchers and 90 on the training bike.
Posted : 14/04/2012 9:11 pm
The 15% rule is where it's at.
cynic-al - Member
eh?
Posted : 14/04/2012 9:13 pm
I just pump them up until my knackered track pump starts leaking air from the seals.
Posted : 14/04/2012 9:16 pm
Same here; are the folk who run different pressures front/rear and wet/dry trolling?
Posted : 14/04/2012 9:29 pm
Generally 95-100psi front & rear
Posted : 14/04/2012 10:38 pm
 aP
No. Better grip and comfort compromise.
Posted : 14/04/2012 10:41 pm
until they are hard 150 for time trials 120 ish for other stuff
Posted : 14/04/2012 10:46 pm
There's no point in worrying about pressures if you're using cheap tyres. Get something good like Michelin Pro 3s and then experiment with pressures.
Posted : 15/04/2012 6:41 am
So moving on to mtb's then shall we....
29er front 40 f, 55 r (rigid ss)
Lefty, 55+55 (alli ht)
Posted : 15/04/2012 7:00 am
Kryton57 - Member
eh?
Actually I'd not read that in detail, but I do tend to run quiet low pressures like it says to.
But then I'm not worried about speed really.
Posted : 17/04/2012 12:46 pm
120 ish on the road bike
35 ish on the MTB
But I am heavy, 95kg or thereabout.
Posted : 17/04/2012 1:18 pm
110/120 f&r although i have no idea how accurate my track pump is.
60 psi must feel very sluggish.
Posted : 17/04/2012 1:22 pm
I'd pinch flat all the time on 60psi.
About a 100 in each tyre for me. Puncture resistance being the main reason.
Similarly MTB tyres go up to about 45-50. A puncture will slow me down a lot more than just losing a little bit of grip.
Posted : 17/04/2012 1:27 pm
115psi front and rear in 23C Specialized Mondo Pros
